Drone Know How
Operating temperature of drones
DimitriBY DimitriPUBLISHED 5 MIN READ
operating temperature drone
Particularly in the cold season, the question of what temperatures you can still fly your drone at arises more frequently. We offer you an overview of the manufacturer’s specifications and further information on the topic of drone operating temperatures.
When temperatures drop below freezing, many drone pilots rightly ask themselves the question„Can I fly my drone in sub-zero temperatures?“. In what temperature ranges is it still safe to fly drones? What is the operating temperature of my drone? The manufacturers usually provide the answer themselves. We have compiled an overview for you.
Overview – Operating temperatures of drones
The temperature ranges at which a drone can be flown are specified by the manufacturers themselves in the technical specifications of their drones. This information can usually be found on the manufacturer’s website or directly in the respective drone manual.
The following table provides you with an overview of the operating temperatures of the most popular drone models. We have taken the information directly from the manufacturers and regularly supplement or adapt it.
DrohneBetriebstemperatur
(laut Hersteller)
DJI Flip-10°C bis +40°C
DJI Mavic Mini0°C bis +40°C
DJI Mini 20°C bis +40°C
DJI Mini 3 Pro-10°C bis +40°C
DJI Mini 4 Pro-10°C bis +40°C
DJI Mini 5 Pro-10°C bis +40°C
DJI Neo-10°C bis +40°C
DJI Mavic Air0°C bis +40°C
DJI Mavic Air 2-10°C bis +40°C
DJI Air 2S0 °C bis +40 °C
DJI Air 3-10 °C bis +40 °C
DJI Air 3S-10 °C bis +40 °C
DJI Mavic Pro0°C bis +40°C
DJI Mavic 2 Pro-10°C bis +40°C
DJI Mavic 2 Zoom-10°C bis +40°C
DJI Mavic 2 Enterprise Advanced-10°C bis +40°C
DJI Mavic 3-10°C bis +40°C
DJI Mavic 4 Pro-10°C bis +40°C
DJI Phantom 4 Pro0°C bis +40°C
DJI Phantom 4 Pro V20°C bis +40°C
DJI Inspire 2-20°C bis +40°C
DJI FPV Drohne-10°C bis +40°C
DJI Avata-10°C bis +40°C
DJI Avata 2-10°C bis +40°C
Parrot ANAFI-10°C bis +40°C
Parrot ANAFI Thermal-10°C bis +40°C
PowerEgg X0°C bis +40°C
Yuneec Typhoon H30°C bis +40°C
Yuneec Typhoon Plus0°C bis +40°C
Xiaomi FIMI X8 Mini0°C bis +40°C
Autel EVO II Pro-10°C bis +40°C
Autel EVO Nano Series-10°C bis +40°C
Autel EVO Lite Series0°C bis +40°C
Hubsan Zino Mini0°C bis +50°C
Hubsan Zino Mini Pro-10°C bis +60°C
Hubsan Zino Mini SE-10°C bis +60°C
But what happens if you fly your drone outside these operating temperatures? The drone will not simply fall out of the sky. The manufacturer’s specifications are usually strictly chosen to protect themselves from complaints. They specify temperature ranges in which they can say with certainty that the drone will not experience any restrictions. There will still be some room for manoeuvre upwards and downwards, but you should not necessarily exhaust this. You are therefore flying at your own risk if you ignore the manufacturer’s specifications. This can be particularly tricky in the event of an insurance claim!
This is because at temperatures above or below the recommended operating temperature, it can no longer be guaranteed that the installed technology will function properly.
This can affect the sensors, motors, camera and, above all, the battery. If temperatures are too cold, the battery can no longer deliver its full performance. As a result, the flight time may be reduced and the battery may „age“ more quickly if used continuously outside of the recommendation.
The error-free functioning of the sensors is also no longer guaranteed. This can lead to unexpected flight behaviour, which in the worst case can result in your drone crashing and becoming defective.
We therefore recommend that you always follow the manufacturer’s instructions and exercise particular caution when flying outside of the recommendations.
Drone insurance
It is also important to mention here that drone liability insurance is mandatory. Even those who operate within the recommended operating temperature ranges cannot avoid taking out appropriate cover within the EU in accordance with the EU Drone Regulation.
Flying a drone in winter – more tips
We have summarised what else you need to consider when flying drones in winter in our guide Flying a drone in winter – what do you need to bear in mind? The manufacturer DJI also provides a suitable article on this topic in its blog.
FAQ Operating temperature of drones
At what temperatures can I fly my drone?
We have compiled a list of the recommended operating temperatures for numerous drone models in the article.
Some drone models are also officially designed for operation in sub-zero temperatures. You can find information on this in our article.
What happens if I fly drones outside the recommended operating temperature?
If drones are flown outside the recommended operating temperature, the correct and safe functioning of all drone components can no longer be guaranteed. Further information can be found in the article.
At what temperature can the DJI Mini 2 be flown?
0°C to 40°C
At what temperature can the DJI Mini 3 Pro be flown?
-10 °C to 40 °C
