Roof and Facade Inspection with Drones
Find and compare drone service providers for your project
Aerial view of a residential building's roof
What our customers say
Customer Reviews
Customer satisfaction is our top priority — that's why we're proud of the many positive reviews of our service. Here's a selection.
We used skyzr's services to inspect our solar panel system. By comparing offers, we quickly found a professional drone provider who helped us solve the problem efficiently.
Thanks to skyzr, we quickly and easily found a suitable drone pilot to film a marketing video inside our hotel. The FPV footage and post-production were delivered exactly as we wanted. We're very happy!
We used skyzr to find a drone pilot for press photos and to document the renovation work on Vienna's public baths. The platform was intuitive to use, and we quickly found the perfect pilot for our project. We're very happy with the results.
Martin KotinskyStadt Wien
How skyzr supports you
Drone Service Providers for Your Building Inspection
Describe your project, compare quotes, hire the right partner.
Commission a drone service provider for one-off or recurring inspections of hard-to-reach building areas such as roofs, rooftop installations, and facades — safer, faster, and more cost-effective than conventional methods. Identify weak points and assess future risks using high-resolution imagery, thermal analysis, or surveying. This also makes it easy to comply with regulations for energy-efficient building renovations and grant requirements.
What your job delivers
Types of Footage and Results
Photos and video, thermal imagery and orthophotos — which capture type fits your building.
Vertical aerial view of a row of terraced houses
Aerial Photos/Videos
Photos and videos are the simplest type of drone footage. As with a standard camera, the drone captures individual photos or continuous video — but from a unique aerial perspective that also makes hard-to-reach areas easy to inspect. This gives you a whole new level of overview and detail.
Thermal Imaging
As a complement to standard photos and videos, specialized drones can also capture thermal imaging from the air. Thanks to the drone's superior vantage point, large or hard-to-reach areas can be surveyed faster too. Thermal imaging provides valuable insight into potential damage or poorly insulated spots on roofs and facades.
Thermal image of a roof
Orthomosaic of a building roof with survey points
Orthophotos and Orthomosaics
Digital drone-based data can be processed and stitched together into highly precise orthomosaic maps. Every pixel contains 2D geographic information (X, Y) and provides precise measurements, such as horizontal distances and area data. This data can be overlaid onto digital plans to track construction progress, and serves as both a visual communication tool and construction site documentation.
What drone inspections deliver
Benefits of Drone Footage for Roof and Facade Inspection
Three reasons roofs and façades are increasingly checked from the air.
Cost-Effective
Where inspections once required scaffolding or lifts to be set up before a qualified person could even make the climb, a single drone pilot on the ground is now enough. No costly equipment purchases, no lengthy setup.
Drone pilot and site manager in front of a building
Fast and Flexible
Drones are quick to set up and ready to fly. The flight itself takes only a fraction of the time normally needed for a roof or facade inspection, while covering far more ground at once. The footage can also be used for further review at a later stage.
Drone flying over a row of terraced houses
Safe
Because a drone-based roof or facade inspection means no one has to make a hazardous climb, this approach is also far safer than conventional methods. For businesses, this type of inspection typically doesn't disrupt operations either — it can be carried out without stopping machinery or pulling other people away from their work.
Tablet displaying drone footage of a tiled roof
Three steps to your quotes
How It Works
From free sign-up to matching quotes takes just a few minutes.
  1. Sign Up
    Sign up for free
  2. Create a Job Listing
    Describe your needs quickly and easily in just a few steps
  3. Receive Quotes
    Get matching quotes from various drone service providers within just 48 hours
Your partner for drone projects
Why skyzr?
We help clients across a wide range of industries commission drone-based services at the best possible value and receive high-quality data.
  • Posting a job in three steps
    Easy Job Posting
    We minimize the effort it takes to commission drone services — and get unique photos, videos, and data — down to almost nothing.
  • Verified credentials of a drone pilot
    Verified Drone Pilots
    High-quality results take experience. That's why only certified, vetted drone pilots are accepted onto skyzr — ensuring every flight is carried out in full legal compliance.
  • Quotes arriving in an inbox
    Quotes Within 48 Hours
    You're guaranteed prompt quotes from multiple drone pilots, so you can compare them side by side.
Further reading
Efficient Roof and Facade Inspection
Use cases and benefits of inspecting from the air in detail.
Discover the impressive benefits of aerial imagery for the roof and facade inspection industry. skyzr gives you access to professional drone pilots who capture high-resolution aerial footage for roof and facade inspections.
Drones offer an efficient and cost-effective solution for inspecting and maintaining buildings — especially roofs and facades. Using drones, hard-to-reach areas can be examined in detail without scaffolding or lifts.
High-resolution aerial imagery makes it possible to spot potential damage, leaks, or other issues early. This supports safety, preserves property value, and improves maintenance planning — helping avoid costly repairs down the line.
See for yourself the many applications and benefits drone technology brings to roof and facade inspection. Successful inspection projects start with skyzr — your platform for professional drone service providers and compelling aerial imagery.
