Wind Turbine Inspection with Drones
Find and compare the right drone service providers for your project
Wind turbine from above
What our customers say
Customer Reviews
Customer satisfaction is our top priority — that's why we're proud of the many positive reviews of our service. Here's a selection.
Thanks to skyzr, we quickly and easily found a suitable drone pilot to film a marketing video inside our hotel. The FPV footage and post-production were delivered exactly as we wanted. We're very happy!
We used skyzr to find a drone pilot for press photos and to document the renovation work on Vienna's public baths. The platform was intuitive to use, and we quickly found the perfect pilot for our project. We're very happy with the results.
Martin KotinskyStadt Wien
How skyzr supports you
Drone Service Providers for Your Wind Turbine
Describe your project, compare quotes, hire the right partner.
Revolutionize wind turbine inspection with cutting-edge drone technology. Drones give you access to even the hardest-to-reach areas, ensuring precise, efficient, and cost-effective monitoring of your turbines. With high-resolution photos and infrared and thermal imaging, drones deliver meaningful data to catch potential problems early. Rely on this innovative approach to maximize the lifespan and efficiency of your wind turbines — and gain a decisive competitive edge in the wind energy industry.
What your job delivers
Imaging Types and Results
High-resolution imagery, thermal scans and 3D models — which result fits your site.
Wind turbine rotor blade from above
High-Resolution Imagery
High-resolution photos let drones capture detailed images of wind turbines, making it possible to inspect rotor blades, tower structures, and other components for damage, wear, or corrosion.
Thermal Imaging
Using infrared or thermal cameras, drones can reveal temperature differences on wind turbines — making it possible to spot leaks, overheating components, or malfunctions early on.
Thermal image of an energy facility
3D model of a wind turbine
3D Modeling and LiDAR
Drones can also create 3D models of wind turbines or use LiDAR (Light Detection and Ranging) technology to carry out precise surveys and analyses of the equipment. These techniques enable a detailed examination of the turbine structure and support the planning of maintenance and repair work.
What drone inspections deliver
Benefits of Drone Imagery for Inspections
Three reasons operators have their sites checked from the air.
Efficient Inspections
Drones enable fast, efficient inspection of wind turbines by delivering detailed images and data in a short amount of time. This significantly cuts inspection times and lets maintenance teams focus on the problem areas identified, reducing the overall maintenance workload.
Wind turbines in a rural landscape
Improved Safety
With drones, inspectors no longer need to climb to dizzying heights to inspect wind turbines. Instead, they can evaluate the data drones collect from a safe distance — reducing the risk of accidents and improving safety for personnel.
Wind farm from above
Early Damage Detection
With high-resolution, infrared, and thermal images, drones provide meaningful insights to catch wear, cracks, or other damage early. Detecting damage early helps avoid costly repairs or unplanned downtime, and contributes to the longevity and efficiency of wind turbines.
Close-up of a nacelle from above
Three steps to your quotes
How It Works
From free sign-up to matching quotes takes just a few minutes.
  1. Sign up
    Sign up for free
  2. Post your job
    Describe what you need in just a few quick, simple steps
  3. Receive quotes
    Get matching quotes from various drone service providers in as little as 48 hours
Your partner for drone projects
Why skyzr?
We help clients across a wide range of industries commission drone-based services at the best possible value, and get high-quality data in return.
  • Posting a job in three steps
    Simple Job Posting
    We keep the effort of commissioning drone services — and getting unique photos, videos, and data — to an absolute minimum.
  • A drone pilot's verified credentials
    Verified Drone Pilots
    High-quality results take real experience. That's why only certified, vetted drone pilots are accepted onto skyzr — ensuring every flight is carried out in full legal compliance.
  • Quotes arriving in your inbox
    Quotes Within 48 Hours
    You're guaranteed prompt quotes from multiple drone pilots, so you can compare them side by side.
Further reading
Effective Wind Turbine Inspection with Aerial Imagery
Use cases and benefits of rotor blade and site inspection in detail.
Discover the impressive benefits drones bring to wind turbine inspection. skyzr connects you with professional drone pilots who capture high-resolution aerial imagery for a detailed analysis of your turbines. Drones offer an efficient, cost-effective solution for inspecting and maintaining wind turbines: they let you examine hard-to-reach areas in detail and catch potential damage early. This helps safeguard safety, preserve asset value, and optimize maintenance planning for your wind energy installations. See for yourself the many use cases and benefits of drone inspection. Successful projects start with skyzr — your platform for professional drone services and meaningful aerial imagery.
