Solar Panel Inspection with Drones
Find and compare the right drone service providers for your project
Customer Reviews
Customer satisfaction is our top priority — that's why we're proud of the many positive reviews of our service. Here's a selection.
Thanks to skyzr, we quickly and easily found a suitable drone pilot to film a marketing video inside our hotel. The FPV footage and post-production were delivered exactly as we wanted. We're very happy!
Lennart de MeulenaereHotel Indigo® ViennaWe used skyzr to find a drone pilot for press photos and to document the renovation work on Vienna's public baths. The platform was intuitive to use, and we quickly found the perfect pilot for our project. We're very happy with the results.
Martin KotinskyStadt WienI'm convinced of the value drone footage adds to real estate marketing. To work efficiently for myself and my clients, I quickly and easily commissioned this service through skyzr.
Denise LauchardLauchard ImmobilienBooking a drone pilot qualified for our specific use case was quick and easy with skyzr — a huge help compared to manually searching for drone pilots on Google.
Manuela Schweighofer-BitterGHS Vermietungs GmbHDrone Service Providers for Your Solar Installation
Describe your project, compare quotes, hire the right partner.
Drones are revolutionizing solar panel inspection by delivering detailed, high-resolution images straight from the air. Thermal cameras make it possible to spot hotspots and potential weak points early, so preventive maintenance can be carried out and downtime kept to a minimum. Harness the power of drone technology and boost the performance of your solar panels.
Imaging Types and Results
Thermal imagery, high-resolution RGB captures and orthophotos — which result fits your site.
Thermal Imaging (Infrared)
Thermal images are captured with infrared cameras and are ideal for inspecting solar panels. They reveal temperature differences and can expose hotspots, faulty cells, or heat loss — all signs of problems or reduced performance.
High-Resolution RGB Imagery
High-resolution RGB (red-green-blue) imagery delivers rich detail in natural colors. These images make it possible to inspect modules, wiring, and mounting hardware for dirt, damage, or corrosion — helping ensure your solar panel system runs at its best.
Orthophotos
Orthophotos are georeferenced aerial images stitched together from multiple overlapping shots. They enable precise surveying and mapping of the solar installation, providing key information on its condition as well as any changes or deviations from the original plans.
Benefits of Drone Imagery for Inspections
Three reasons operators have their sites checked from the air.
Efficient Hotspot Detection
Drones equipped with thermal cameras enable fast, accurate identification of hotspots on solar modules. These hotspots can indicate power loss, defective cells, or dirt buildup. Early detection allows for targeted maintenance measures that keep the system running at peak efficiency.
Time Savings and Safety
Inspecting solar panels with drones saves time, since they can cover large areas quickly. Drones also make inspections safer, as staff no longer need to work at dangerous heights or on uneven terrain — minimizing risk and lowering inspection costs.
Detailed, High-Resolution Imagery
Drones capture high-resolution images and video that enable detailed analysis of the system. They can detect the smallest faults and defects that are hard to spot with the naked eye. This information helps optimize maintenance strategy and extend the lifespan of your solar panel system.
How It Works
From free sign-up to matching quotes takes just a few minutes.
Sign up
Sign up for freePost your job
Describe what you need in just a few quick, simple stepsReceive quotes
Get matching quotes from various drone service providers in as little as 48 hours
Why skyzr?
We help clients across a wide range of industries commission drone-based services at the best possible value, and get high-quality data in return.
Simple Job Posting
We keep the effort of commissioning drone services — and getting unique photos, videos, and data — to an absolute minimum.
Verified Drone Pilots
High-quality results take real experience. That's why only certified, vetted drone pilots are accepted onto skyzr — ensuring every flight is carried out in full legal compliance.
Quotes Within 48 Hours
You're guaranteed prompt quotes from multiple drone pilots, so you can compare them side by side.
Efficient Solar Panel Inspection with Aerial Imagery
Use cases and benefits of inspecting installations from the air in detail.
Discover the impressive benefits drones bring to solar panel inspection. skyzr connects you with professional drone pilots who capture high-quality aerial imagery for a detailed analysis of your systems. Drones offer an efficient, cost-effective solution for inspecting and maintaining solar panels: they let you examine hard-to-reach areas in detail and catch potential damage early. This helps safeguard safety, preserve asset value, and optimize maintenance planning for your solar installations. See for yourself the many use cases and benefits of drone inspection. Successful projects start with skyzr — your platform for professional drone services and meaningful aerial imagery.
