Buy a drone
The best alternatives to DJI drones
DimitriBY DimitriPUBLISHED 9 MIN READ
dji alternative drones
If you are looking at alternatives to DJI drones, you will quickly come across numerous other drone manufacturers with exciting products. We provide you with an overview of some DJI alternatives.
DJI has established itself as the market leader in the drone industry and offers a wide range of drones for different applications and budgets. However, despite the popularity of DJI models, there are other manufacturers that offer high quality drones. In this article, we will present the best alternatives to the most popular DJI drones, taking into account the most important criteria such as price, features, camera quality, flight time and range. We will focus on the DJI Mavic 3, DJI Mini 3, DJI Air 2S, DJI Phantom 4 and DJI Inspire 2 models, and compare them to selected competitor products.
DJI drones at a glance
Before we look at the alternatives, we take a quick look at the most popular DJI drone models and their pros and cons. We then provide an alternative from another manufacturer for each model.
DJI Mavic 3
  • Pros: Excellent camera quality, long flight time, long range
  • Disadvantages: High price, larger and heavier than other models
DJI Mini 3
  • Pros: Compact size, light weight, affordable price
  • Disadvantages: Limited features compared to larger models
DJI Air 2S
  • Pros: Good camera quality, solid flight time and range, lots of features
  • Disadvantages: Slightly more expensive, larger and heavier than the mini series
DJI Phantom 4
  • Pros: Professional camera quality, very good flight time and range
  • Disadvantages: Expensive, large and heavy, less portable, now a little older
DJI Inspire 2
  • Pros: High quality camera options, very good flight time and range
  • Cons: Very expensive, large and heavy
The best DJI alternatives compared
Below you will find the best alternatives for each of the DJI drone models mentioned above.
Note: We only list one alternative for each DJI model. There are, of course, other models on the market and sometimes different versions of the same model. The following list does not provide a complete list of all alternatives, but only the most suitable ones in our opinion. Feel free to use this list as a starting point to let us show you some alternatives.
Autel Robotics EVO II (alternative to the DJI Mavic 3)
The EVO II from Autel Robotics is an impressive alternative to the DJI Mavic 3, offering an 8K camera that allows for stunning image quality. With a flight time of up to 40 minutes and a range of 9 km, it is in no way inferior to the Mavic 3.
Pros:
  • Good camera quality
  • Long flight time
  • Comparable range
Disadvantages:
  • Slightly more expensive than the Mavic 3
  • Fewer accessories available
Technical specifications:
  • up to 8K camera depending on model
  • 40 minutes flight time
  • 9 km range
Price comparison: similar price to the DJI Mavic 3
Hubsan Zino Mini Pro (alternative to the DJI Mini 3)
The Hubsan Zino Mini Pro is a compact and lightweight drone that can serve as an alternative to the DJI Mini 3. With a 4K camera, it delivers good image quality while being easy to transport. The flight time is up to 40 minutes and the range is 10 km.
Advantages:
  • Compact size
  • Light weight
Disadvantages:
  • Shorter flight time and range than the DJI Mini 3
  • 4K camera
  • 10 km range
Price comparison: Lower price than the DJI Mini 3
Parrot Anafi (alternative to the DJI Air 2S)
The Parrot Anafi is a solid alternative to the DJI Air 2S. It has a 4K HDR camera that allows for impressive footage and offers a flight time of 25 minutes and a range of 4 km. It also weighs less than the Air 2S.
Pros:
  • Upward tilting camera
  • Solid flight time and range
  • Lower weight
Disadvantages:
  • More limited features than the DJI Air 2S
  • 4K HDR camera
  • 25 minutes flight time
  • 4 km range
Price comparison: Che aper than the DJI Air 2S
Yuneec Typhoon H3 (alternative to the DJI Phantom 4)
The Yuneec Typhoon H3 is a professional drone that can be considered as an alternative to the DJI Phantom 4. It has a 4K camera and offers good flight times of 25 minutes and a range of 2 km. A unique feature of the Typhoon H3 is its six-rotor design, which provides extra stability.
Advantages:
  • Professional camera quality
  • Good flight time and range
  • Six rotors for added stability
Disadvantages:
  • More expensive, larger and heavier than the Phantom 4
  • 4K camera
  • 2 km range
Price comparison: Similar price to the DJI Phantom 4
Freefly Systems Alta X (alternative to the DJI Inspire 2)
The Freefly Systems Alta X is a powerful drone that can serve as an alternative to the DJI Inspire 2. It is compatible with various camera options, has a flight time of up to 35 minutes and offers a range of 5 km. Its robust design makes it ideal for professional applications.
Advantages:
  • Customisable camera options
  • Very good flight time and range
  • Robust design
Disadvantages:
  • Very expensive
  • Large and heavy
  • Less suitable for hobby users
Technical data:
  • Compatible with various camera options
  • Up to
  • 35 minutes flight time
  • 5 km range
  • Price comparison: Significantly more expensive than the DJI Inspire 2
What to look for when searching for DJI alternatives
When looking for alternatives, you should pay attention to the following criteria:
  1. Price
  2. Features
  3. Camera quality
  4. Flight time
  5. Range
  6. Size and weight
  7. Spare parts and repair options
Price: DJI drones are often more expensive than their competitors. If you have a limited budget, you should look for cheaper alternatives. However, there are also drones that are in the same price range as DJI products, but may offer more features or better camera quality.
Features: Think about what features are important for your intended use. For example, do you need a drone with a long flight time or a long range? Or do you value good image quality and want a drone with a high-quality camera? Control and navigation are also important factors to consider when choosing a drone.
Camera quality: If you want to use the drone for aerial photography or film production, you should look for good camera quality. Most drones offer a camera with a resolution of 1080p or 4K, although 4K has long been established as the standard. However, some models also have a higher resolution or special features.
Flight time: Flight time is an important factor to consider when choosing a drone. The longer the flight time, the longer you can keep the drone in the air and take pictures. Most drones offer a flight time of 20 to 30 minutes, but there are also models that have a longer flight time.
Range: The range indicates how far the drone can fly from the remote control. The greater the range, the further you can fly the drone and take pictures. Most drones have a range of around 2 to 4 kilometres. However, be aware of legal requirements that limit the possible range of drones.
Size and weight: The size and weight of the drone are important if you want to transport it. The smaller and lighter the drone, the easier it is to transport. However, larger drones can also be more stable in the air and are better suited for use in high winds.
Spare parts and repair options: It is important to have spare parts and repair facilities available for the drone in case of damage. Therefore, check whether spare parts are available for your chosen drone and whether repairs can be carried out. Whether by yourself or by suitably qualified partners.
Bonus: Tips on drone flying and insurance
What you should bear in mind when flying a drone:
  1. Find out about the legal requirements in your country.
  2. Avoid flying near airports, residential areas and crowds.
  3. Be aware of weather conditions and avoid strong winds or rain.
  4. Learn the basics of drone control and practice in an open, safe area.
For more information, read our in-depth article Learning to Fly a Drone – What You Need to Know.
The most important information about drone insurance:
  1. Liability insurance is required by law.
  2. Insurance should cover damage to third parties and their property.
  3. Consider comprehensive insurance to cover damage to your own drone.
  4. Compare prices and services of different providers before you decide.
We have already written an extensive article on this topic and give you a recommendation for your drone liability insurance : Drone Insurance: Liability Comparison
Summary
Choosing the best DJI alternative depends on your budget, your requirements and your personal preferences. Here are our recommendations depending on your intended use:
  • Performance winner: Autel Robotics EVO II
  • Price-performance: Parrot Anafi
  • Compact and lightweight: Hubsan Zino Mini Pro
  • Professional use: Yuneec Typhoon H3
In this article, we took an in-depth look at alternatives to the popular DJI drones. There are many alternatives on the market that can be a good choice depending on your needs and budget. Be sure to compare the different models carefully and decide based on your needs.
The drone industry is constantly evolving and we can expect many more exciting innovations in the coming years. From improved camera systems to longer flight times and new uses, the world of drones offers endless possibilities. So stay tuned and keep up to date with the latest developments to get the most out of your drone flying experience.
We hope this article helps you find the perfect drone for your needs and hope you enjoy flying it!
Which drone is comparable to DJI?
There are several models that can be mentioned here. You can find a list in the article.
Who is the market leader in drones?
The Chinese drone manufacturer DJI is considered the market leader for private and commercial drones.
What will DJI bring next?
The article provides an overview of possible new DJI products.
What is the alternative to the DJI Mavic 3?
As an alternative to the DJI Mavic 3, we can recommend the Autel EVO II. Details can be found in the article.
What is the alternative to the DJI Mini 3?
As an alternative to the DJI Mini 3, we can recommend the Hubsan Zino Mini Pro. Details can be found in the article.
