DJI Avata memory cards and internal memory
In the following article, you will learn whether a memory card is necessary for the DJI Avata, which microSD memory cards are suitable, how large they can be and how large the internal memory of the Avata FPV drone is.
DJI Avata internal memory
The DJI Avata comes without a separate memory card. So the first question that comes to mind here is: do I need a memory card for the DJI Avata? The drone itself has 20GB of internal memory. That’s not even that little for a drone, compare that to the small 1.2GB internal memory on the DJI Mini 3 Pro . A memory card is therefore not absolutely necessary. Depending on the extent of the recordings, especially in 4K resolution, the 20GB can be filled relatively quickly.
Then an additional SD memory card is recommended and necessary. According to the technical specifications, the DJI Avata supports memory cards with a size of up to 256GB.
Suitable memory cards for the DJI Avata
On the DJI website, there are some recommendations for suitable memory cards for the DJI Avata drone. In the following list, we summarize them for you with current prices. The recommendations range from memory cards with 32GB up to the maximum possible 256GB. The list provides an excerpt of possible memory cards and is not a complete list of all compatible cards on the market. So far, we have had good experiences with the SandDisk cards across numerous drones and capacity sizes.
The recommendation
DJI also recommends the following memory cards:
We keep the list up to date as far as possible and add new models as needed. Apart from the above recommendations, there is of course another variety of suitable memory cards for the Avata drone on the market.
DJI Avata Memory Cards FAQ
No, the DJI Avata does not come with a memory card. You can find out which memory cards are suitable in our article.
No, not necessarily. Since the DJI Avata has internal memory, it can also store images without separate memory cards. Depending on the number and length of the shots, an additional memory card makes sense.
The Avata has 20GB of internal memory.
The Avata supports memory cards with a size of up to 256GB. Recommendations for suitable models can be found in the article.
