DJI Avata
DJI Avata Firmware Update v01.03.0000
DimitriBY DimitriPUBLISHED 3 MIN READ
The latest DJI Avata firmware update v01.03.0000 primarily brings support for the new Goggles Integra and the RC Motion 2 remote control. However, there are also other functions and adjustments. As always, we provide you with the latest patch notes.
With the latest firmware update for the DJI Avata, DJI provides support for the new FPV accessories consisting of DJI Goggles Integra video goggles and the DJI RC Motion 2 remote control. If you want to use the new devices with your Avata drone in the future, it is mandatory to have at least v01.03.0000 of the Avata firmware installed. The update also requires the DJI Fly app version 1.9.8 or higher.
In addition to the support of the new products, the update also provides a new function for resetting and deleting data from the drone, additional warnings for weak connections and extends the RTH countdown to 15 seconds. The following is a detailed overview of the new features and changes.
Overview of DJI Avata Firmware v01.03.0000
  • Date: 2023.03.28
  • Aircraft Firmware: v01.03.0000
  • Goggles Firmware:
  • v01.05.0000 (DJI Goggles 2)
  • v01.07.0000 (DJI FPV Goggles V2)
  • v01.01.0000 (DJI Goggles Integra)
  • Remote Control Devices Firmware:
  • v02.00.0600 (DJI FPV Remote Controller 2)
  • v02.00.0600 (DJI Motion Controller)
  • v01.01.0000 (DJI RC Motion 2)
  • DJI Fly App iOS: v1.9.8
  • DJI Fly App Android: v1.9.8
Patchnotes DJI Avata Firmware v01.03.0000
  • Added support to use with DJI RC Motion 2.
  • Added support to use with DJI Goggles Integra.
  • Added erasing all aircraft data. Tap Settings > About > Clear All Data to erase all data.
  • Added RTH altitude prompt after updating the Home Point.
  • Extended the low battery RTH countdown to 15 seconds.
  • Added visual prompts when remote control or image transmission signals are weak. The visual prompt is displayed only when the aircraft is used with the DJI Goggles 2 or DJI Goggles Integra.
Source: forum.dji.com
Notes
Restart the aircraft, remote control and goggles after the update is complete.
Note that the update may reset various flight parameters such as RTH altitude and maximum flight distance. Make a note of your preferred settings before the update and adjust them after the update.
Perform DJI Avata Firmware Update
If you want to know how to update the DJI Avata drone firmware, the following article will help you with a step-by-step guide: Perform DJI Avata Firmware Update. If you have problems with the update, it is often enough to restart all devices and try again.
