DJI Mini 3 Pro firmware updates at a glance
11 Min. Lesezeit
Wir liefern euch die Patchnotes zum aktuellen DJI Mini 3 Pro Firmware Update
Get an overview of current and past DJI Mini 3 Pro firmware updates here.
Overview of the DJI Mini 3 Pro firmware v01.00.0600
When DJI launches new products on the market, you can always expect numerous updates. For example, the new firmware version for the Mini 3 Pro. The drone now officially receives support for the FPV video goggles DJI Goggles 2, DJI Goggles Integra and the remote control DJI RC Motion 2.
In addition to the firmware update mentioned here, at least the DJI Fly app version 1.10.0, which was also released this week, is required to use the new hardware.
  • Date: 2023.04.25
  • Aircraft firmware: v01.00.0600
  • Remote Controller Firmware: v03.02.01.00(DJI RC Pro)
  • v01.03.01.00(DJI RC)
  • v04.14.06.00(DJI RC-N1)
  • DJI Fly App iOS: v1.10.0
  • DJI Fly App Android: v1.10.0
Patch notes DJI Mini 3 Pro Firmware v01.00.0600
  • Support for DJI Goggles 2, DJI Goggles Integra and DJI RC Motion 2 has been added.
Source: forum.dji.com
Notes
If the firmware update of the DJI Mini 3 Pro to version 01.00.0600 fails, restart the drone, the remote control and the DJI Fly App or the DJI Assistant 2 (Consumer Drones Series) and try again. This often helps to solve most update problems.
Perform DJI Mini 3 Pro firmware update
We have explained how you can update the firmware of the DJI Mini 3 Pro in two simple ways in a separate article – Performing a DJI Mini 3 Pro firmware update.
Overview of the DJI Mini 3 Pro firmware v01.00.0500
The new DJI Mini 3 Pro firmware update v01.00.0500 is the first new version since the release of v01.00.0400 in October 2022. Although there are no major new functions for flying the drone with the update, there are now some new settings for the DJI Mini 3 Pro in the settings. These include, for example, the option to reset all settings and delete all data. Other new settings for some flight parameters are also included. You can find the details below in the update overview.
  • Date: 2023.03.28
  • Aircraft firmware: v01.00.0500
  • DJI RC-N1 Remote Controller Firmware: v04.14.0400
  • DJI RC Remote Controller Firmware: v01.02.0500
  • DJI RC Pro Remote Controller Firmware: v03.01.1200
  • DJI Fly App iOS: v1.9.8
  • DJI Fly App Android: v1.9.8
Patch notes DJI Mini 3 Pro Firmware v01.00.0500
What’s new?
  • The options Reset all settings and Delete all data have been added. Details can be found in the Mini 3 Pro user manual v1.6.
  • Gain and expo tuning added. The maximum airspeed, brake sensitivity and other settings can be adjusted in various flight modes.
Notes
The new functions of the update require the DJI Fly App in version 1.9.8. If the firmware update of the DJI Mini 3 Pro fails, restart the drone, the remote control and the DJI Fly App or the DJI Assistant 2 (Consumer Drones Series) and try again. This often helps to solve most update problems.
Overview of the DJI Mini 3 Pro firmware v01.00.0400
The new Mini 3 Pro firmware update is the first update in around 4 months. Version 01.00.0400 focuses on several new functions. The important support for Remote ID has been added, especially for users in the USA. However, owners outside the United States can also look forward to some new functions for the Mini 3. These include, for example, the long-requested use of MasterShots in portrait mode. We summarise all other new features in the following section.
  • Date: 2022.10.26
  • Aircraft firmware: v01.00.0400
  • DJI RC Remote Controller Firmware: v01.02.0000
  • DJI RC Pro Remote Controller Firmware: v03.01.1000
  • DJI Fly App iOS: v1.7.8
  • DJI Fly App Android: v1.7.8
Patch notes DJI Mini 3 Pro Firmware v01.00.0400
  • Added support for FAA requirements for Remote ID in the United States.
  • Support for the use of MasterShots in portrait mode has been added.
  • Shutter priority and ISO priority for the camera in Pro mode have been added.
  • Support for setting style parameters such as sharpness and noise reduction has been added.
  • Support for the use of wide-angle lenses has been added.
Notes
Some functions of the update require the DJI Fly App in version 1.7.8. If the firmware update of the DJI Mini 3 Pro fails, restart the drone, the remote control and the DJI Fly App or the DJI Assistant 2 (Consumer Drones Series) and try again. This often helps to solve most update problems.
Overview of the DJI Mini 3 Pro firmware v01.00.0201
The first “real” firmware update since the release of the DJI Mini 3 Pro and the update to v01.00.0100 brings some new features and improvements and takes care of some bugs.
Among other things, the update adds numerous new shooting modes for the portrait mode of the Mini 3 Pro. FocusTrack, QuickShots and Hyperlapse recordings are now possible in portrait mode. A 2-second interval has also been added for Hyperlapse mode.
A new USB mode on the DJI Mini 3 Pro is also designed to protect the battery when the Mini 3 is connected to a computer for data exchange. This option can be activated under Camera view -> Settings -> Camera.
An AF-C mode (continuous autofocus) is now also available for video recording.
You can find details of all the other changes in the firmware update in the patch notes below.
  • Date: 2022.06.30
  • Aircraft firmware: v01.00.0201
  • DJI RC-N1 Remote Controller Firmware: v04.14.0221
  • DJI RC Remote Controller Firmware: v01.01.0000
  • DJI Fly App iOS: v1.6.8
  • DJI Fly App Android: v1.6.8
Patch notes DJI Mini 3 Pro Firmware v01.00.0201
What’s new?
  • Added support for FocusTrack, QuickShots (Dronie, Rocket, Circle, Helix and Boomerang) and Hyperlapse in portrait format.
  • Added a two-second interval setting option when using Hyperlapse after startup.
  • Support for continuous autofocus (AF-C) during video recording has been added.
  • USB mode added. When the aircraft is connected to a computer and USB mode is enabled, the aircraft disables image transfer to increase the time it takes to copy recordings.
What has been updated?
  • The speed of the camera when taking photos has been increased.
  • The stability of videos when using Hyperlapse has been increased.
  • The dynamic range for Hyperlapse has been increased.
  • Optimised image quality for night shots in D-Cinelike.
  • The anti-interference capability and the transmission distance of the image transmission system have been optimised.
  • The correctness of the battery status display on the DJI RC-N1 remote control has been optimised.
  • The management of the battery charge when flying in environments with strong winds has been optimised.
What has been fixed?
  • Problem fixed: The videos recorded in D-Cinelike in some scenarios flickered.
  • A problem has been fixed: When selecting intelligent flight modes in portrait mode, an incorrect prompt appeared on the DJI RC remote controller or an Android device.
  • The vignetting effect in DNG photos has been optimised.
Source: DJI Forum
Block has been deleted or is not available.
Notes
Some functions of the update require the DJI Fly App in version 1.6.8. If the firmware update of the DJI Mini 3 Pro fails, restart the drone, the remote control and the DJI Fly App or the DJI Assistant 2 (Consumer Drones Series) and try again. This often helps to solve most update problems.
Overview of the DJI Mini 3 Pro firmware v01.00.0100
The launch of every new DJI drone is always accompanied by an initial firmware update. This usually provides basic functions for the operation of the drone. This is now also the case with the firmware update v01.00.0100 for the DJI Mini 3 Pro.
It provides important functions for the operation of the drone and makes it truly usable. It is therefore essential to install the update in order to operate the Mini 3 Pro. It is also necessary to update the DJI Fly app to the newly released version 1.6.1.
dji mini 3 pro firmware update v01-00-0100
The official patch notes of the DJI Mini 3 Pro firmware update v01.00.0100
  • Date: 2022.05.17
  • Aircraft firmware: v01.00.0100
  • DJI RC-N1 Remote Controller Firmware: v04.14.0117
  • DJI RC Remote Controller Firmware: v01.00.0100
  • DJI Fly App iOS: v1.6.1
  • DJI Fly App Android: v1.6.1
Patch notes DJI Mini 3 firmware v01.00.0100
  • True vertical photography added.
  • FocusTrack was added
  • APAS 4.0 (Advanced Pilot Assistance Systems) has been added
  • Hyperlapse was added
  • MasterShots added
  • QuickShots added
  • QuickTransfer added
  • Panorama added
  • 4K/48fps, 4K/50fps and 4K/60fps added
  • Slow motion 1080p/120fps added
  • Significantly improved image quality
  • Optimised flight stability.
Source: DJI Forum
Notes
