How to update DJI Mini 4 Pro firmware
In this tutorial you will learn how to update the DJI Mini 4 Pro firmware. There are two simple ways to update the firmware.
DJI Mini 4 Pro Firmware Update – Instructions
DJI provides two methods for updating the DJI Mini 4 Pro firmware. Directly via the DJI Fly app, or via a PC/Mac using the DJI Assistant 2 software (Consumer Drone Series). The most convenient option is directly through the Fly App, as there is no need to go through another device. Sometimes, however, problems can occur, then the way via the additional software usually helps. In the following, we will show you how both processes work step by step. We explain the firmware upgrade process in detail.
The necessary downloads:
- Smartphone: DJI Fly App*
- PC/Mac: DJI Assistant 2 (Consumer Drones Serie)*
DJI Mini 4 Pro Firmware Update via DJI Fly App
- Start your DJI Mini 4 Pro including the remote control.
- Then connect the drone and the remote control together.
- After successful connection, the DJI Fly app will automatically check the firmware version. If a new firmware update is available, a prompt will appear in the Fly App.
- Go to the firmware update home page and tap „Update“.
- Do not exit or turn off the DJI Fly app during the update process.
- After the firmware update is complete, the DJI Mini 4 Pro will automatically reboot.
DJI Mini 4 Pro Firmware Update with DJI Assistant 2
When updating the firmware via DJI Assistant, this must be done separately for the drone itself and the remote control. This is because during the update process, the drone and remote control are not connected to each other, but are connected one after the other via the PC/Mac.
DJI Mini 4 drones firmware update
- Turn on the DJI Mini 4 Pro.
- Connect the drone to your computer using a USB cable.
- Launch DJI Assistant 2 (Consumer Drones series), log in and select the DJI Mini 4 Pro.
- Select „Firmware Update“ from the menu on the left.
- After the software has updated and displayed the firmware versions, select the most recent version and click Upgrade.
- During the upgrade process, do not exit DJI Assistant 2, remove the USB cable, or turn off the DJI Mini 4 Pro.
Remote control (RC-N2/RC 2) Update firmware
- First, turn on the remote control of the DJI Mini 4 Pro (RC-N2 or RC 2).
- Connect the remote control to your computer using a USB cable.
- Launch DJI Assistant 2 (Consumer Drones series), log in and select the device (DJI RC-N2).
- After the software updates and displays the firmware version, select the most recent firmware version and click Upgrade.
- During the upgrade process, do not exit DJI Assistant 2 or remove the USB cable to the remote control.
- After the firmware update is complete, the remote control will restart automatically.
- Unter 249 g, kein Drohnenführerschein erforderlich[1] – Leicht, konform mit den C0-Vorschriften, in den meisten Ländern ist keine Drohnenführerschein erforderlich; Genieße den Spaß am Fliegen ohne mühsames Antragsverfahren und Wartezeit
Problems with the firmware update of the DJI Mini 4 Pro – The following steps can help
In most cases, firmware updates run without problems. However, if there are still problems, this is no reason to despair. The following steps can help you to solve problems.
- Make sure the battery is at least 50% charged before you start an update. This applies to both the drone and the remote control.
- Make sure your smartphone is compatible with the DJI Fly app.
- Reboot the drone and remote control and try the update again.
FAQ Perform DJI Mini 4 Pro Firmware Update
There are two ways to do this. Either directly via the DJI Fly app or via the DJI Assistant 2 software (Consumer Drones series). In our article we describe both options step by step.
Either directly via the DJI Fly app or via the DJI Assistant 2 software (Consumer Drones series). For both ways, we have summarized step-by-step instructions in the article.
Yes, regular updates ensure stable operation of the drone. They often contain new functions in addition to bug fixes.
