Interactive map
Our risk map is at the heart of wingman – it combines current data on ground and air risks with your input and visualises the risk of your flight in a granular but clear format.
This allows you to quickly identify risks, make adjustments to your flight plan via wingman and calculate the new risk class.
Visualising risk along the flight plan
wingman displays the area in and around your flight zone in the form of hexagons with a diameter of 100 metres. Based on a colour scale, you can see at a glance which areas of the flight pose a higher risk. You can also view ground and air risks separately.
Flexibly select and deselect map layers
The map allows for comprehensive analysis by displaying additional layers such as obstacles, POIs or model and gliding areas. On the ground, a distinction is also made between populated and urban areas. In the air, the visualisation of airspace responds flexibly to the set altitude setting.
Prices
Free
0€
Enjoy our free features
- Create & Manage Accounts
- Manage Drones/Assets
- Manage Documents
- Use Risk Visualization Map
- Create SORA
- Save SORA Drafts
- Generate & share SORA Export
- Invite multiple users
- SORA version control
- Version change log
- Customizations (on demand)
- API integration (on demand)
SPECIFIC BASIC
Popular
199€ / month
Must-have for SPECIFIC flights
- Manage Documents
- Cancel subscription anytime
- Create SORA
- Save SORA Drafts
SPECIFIC PLUS
299€ / Month
Perfect for complex operations
- Manage Documents
- Create SORA
- Save SORA Drafts
