Inspection of wind turbines with drones
Find and compare suitable drone service providers for your project
Customer reviews
Customer satisfaction is our top priority. We are therefore delighted with the many positive comments about our service.
Revolutionize the inspection of wind turbines with the latest drone technology. By using drones, you can reach even hard-to-access areas and ensure precise, efficient and cost-effective monitoring of your turbines. With high-resolution photos, infrared and thermal imaging, drones provide meaningful data to identify potential problems at an early stage. Rely on this innovative method to maximize the service life and efficiency of your wind turbines and secure a decisive competitive advantage in the wind energy industry.
Recording types and results
drohnen inspektion windkraftanlage windturbine
High-resolution recordings
With high-resolution photos, drones can capture detailed images of wind turbines to inspect rotor blades, tower structures and other components for damage, wear or corrosion.
Thermal imaging
With the help of infrared or thermal imaging cameras, drones can make temperature differences on wind turbines visible. This allows leaks, overheated components or malfunctions to be detected at an early stage.
drohne photovoltaik inspektion
drohne widnkraftanlage 3d modell
3D modeling and LiDAR
Drones can also create 3D models of wind turbines or use LiDAR (Light Detection and Ranging) technology to carry out precise measurements and analyses of the turbines. These techniques enable a detailed examination of the turbine structure and help with the planning of maintenance and repair work.
Advantages of drone footage for inspections
Efficient inspections
Drones enable fast and efficient inspection of wind turbines by providing detailed images and data in a short space of time. This significantly reduces inspection times and allows maintenance teams to focus on identified problem areas, reducing the overall maintenance effort.
Improving security
By using drones, inspectors no longer have to climb to dizzying heights to inspect wind turbines. Instead, they can evaluate the data collected by the drones from a safe distance. This reduces the risk of accidents and increases the safety of personnel.
drohnen inspektion windkraftanlage 2
Early damage detection
With high-resolution images, infrared and thermal images, drones provide meaningful information to detect wear, cracks or other damage to the turbines at an early stage. This early detection of damage helps to avoid expensive repairs or unplanned outages and contributes to the longevity and efficiency of wind turbines.
How it works
Register
Register for free
Create job
Describe your requirements quickly and easily in just a few steps
Receive offers
Receive suitable offers from various drone service providers after just 48 hours
Why skyzr?
We support customers from a wide range of industries in commissioning drone-based services at the best price-performance ratio and obtaining high-quality data.
drohnenpilot einfach finden
Simple order entry
We minimise the time and effort you spend on hiring drone services and thus on unique photos, videos and data.
drohnenpilot zertifiziert
Certified drone pilots
High-quality results require a lot of experience. That’s why only certified and tested drone pilots are accepted on skyzr. In this way, we ensure legally compliant flight operations.
Offers within 48 hours
You are guaranteed to receive prompt offers from several drone pilots and can compare them directly with each other.
Effectively inspect wind turbines thanks to aerial photography
Discover the impressive benefits of drones for the inspection of wind turbines. skyzr offers you access to professional drone pilots who create high-resolution aerial images for a detailed analysis of your turbines. Drones offer an efficient and cost-effective solution for the inspection and maintenance of wind turbines. By using drones, areas that are difficult to access can be examined in detail and potential damage can be detected at an early stage. This contributes to the safety, value retention and optimized maintenance planning of your wind turbines. Convince yourself of the many possible applications and advantages of drone inspections. Successful projects start with skyzr – your platform for professional drone services and informative aerial images.
Relevant articles for your industry
