Set new standards in real estate marketing: discover the advantages of breathtaking drone shots and give your properties a unique perspective
Find and compare suitable drone service providers for your project
Customer satisfaction is our top priority. Therefore, we are pleased about the numerous positive comments about our service.
Hire a drone service provider for spontaneous or regular inspections of hard-to-reach building areas such as roofs, roof systems and facades and be safer, faster and more cost-effective than with conventional methods. Identify vulnerabilities and assess future risks using high-resolution imagery, thermal analysis, or surveying. Easily comply with regulations for building energy retrofits and grants.
According to MLS statistics, properties whose listings have aerial photography sell 68% faster than listings without such photography.
Take advantage of this potential today!
Photos and videos are the simplest type of drone footage. As with standard cameras, the drone takes individual photos or a continuous video, which, however, benefit from the unique perspective from the air and make even hard-to-reach places effortlessly visible. Thus, these recordings enable a completely new overview and level of detail.
In addition to simple photos and videos, special drones can also provide thermal images from the air. Due to the better overview provided by drones, more areas or areas that are difficult to access can be captured more quickly. Thermal images provide you with important information about possible damage or poorly insulated areas on roofs or facades.
Digital drone-based data can be processed and assembled into high-precision orthomosaic maps. Each pixel contains 2D geo-information (X, Y) and provides precise measurements, such as horizontal distances and surface information. This data can be overlaid on digital plans to track construction progress and serves as a visual communication tool and site documentation.
Where inspections first required the erection of appropriate scaffolding or the procurement of lifting platforms before a qualified person could dare to ascend, a single drone pilot on the ground is now all that is needed. No expensive purchases, no lengthy set-up of additional equipment.
Drones are quickly commissioned and ready for use. Moreover, the actual flight can be performed in a fraction of the time otherwise required for a roof inspection/facade inspection, while at the same time many more areas can be covered at once. Furthermore, the recordings can still be used for further inspections afterwards.
Since no person has to dare a dangerous ascent during a drone-based roof or facade inspection, this variant is also significantly safer than the conventional method. In addition, this type of inspection does not usually interfere with ongoing operations at companies - the inspection can be carried out without having to start machines or stop other people from working.
Describe your requirements using our intuitive step-by-step form
We will check your details and get back to you immediately for final details
Receive suitable offers from different drone service providers after only 48 hours
Register for free
Describe your needs quickly and easily in just a few steps
We support customers from a wide range of industries in commissioning drone-based services at the best price-performance ratio and obtaining high-quality data.
We minimize your effort to hire drone services and therefore unique photos, videos and data.
For high-quality results, you need a lot of experience. Therefore, only certified and tested drone pilots are accepted on skyzr. Thus, we ensure a legally compliant flight performance.
You are guaranteed to receive timely quotes from multiple drone pilots and can compare them directly.
Discover the impressive benefits of aerial photography for the roof and facade inspection industry. skyzr offers you access to professional drone pilots who create high-resolution aerial photographs for roof and facade inspections.
Drones offer an efficient and cost-effective solution for the inspection and maintenance of buildings, especially roofs and facades. By using drones, areas that are difficult to access can be examined in detail without scaffolding or lifting platforms.
The high-resolution aerial images make it possible to detect potential damage, leaks or other problems at an early stage. This contributes to safety, value retention and optimized maintenance planning and avoids expensive repairs in the long term.
See for yourself the wide range of applications and benefits of drone technology for roof and facade inspection. Successful inspection projects start with skyzr - your platform for professional drone service providers and meaningful aerial images.
