Calculate ground and air risk
Step by step, wingman helps you enter all the necessary information about flight parameters and times, altitude and speed.
You can either draw the flight plan directly in wingman or upload it as a file. You can easily assign the drone used, including its technical data, from the equipment pool. In a matter of seconds, you will receive your risk classes according to the SORA method.
Concept of Operations
After a pre-evaluation, the first step in SORA is your Concept of Operations. This is usually provided as a separate document and can be uploaded at this stage. You can also provide various declarative details about your flight, such as Controlled Ground Area or Atypical Airspace.
Concept of Operations - Drones
An important step in this process is selecting the drone(s). These can be easily selected and assigned from your previously created equipment pool. The technical data of the drone is then automatically transferred for risk calculation.
Define flight plan and flight parameters
In the next step, you can specify whether you want to fly during the day and/or at night and define important characteristics of your flight, such as maximum altitude or maximum planned speed. Wingman helps you calculate the contingency area and ground risk buffer with automatic calculations, saving you a lot of time and effort.
Calculate initial SAIL
Based on your information and flight plan, our Risk Engine automatically calculates the initial SAIL, consisting of ground risk and air risk. Wingman follows the SORA 2.0 method in detail, which is currently also used by the relevant authorities. From here, you can view details about the risk along the flight plan by navigating to the map. You can also declare various mitigations, the effects of which are also automatically calculated according to the SORA method.
Prices
Free
0€
Enjoy our free features
- Create & Manage Accounts
- Manage Drones/Assets
- Manage Documents
- Use Risk Visualization Map
- Create SORA
- Save SORA Drafts
- Generate & share SORA Export
- Invite multiple users
- SORA version control
- Version change log
- Customizations (on demand)
- API integration (on demand)
SPECIFIC BASIC
Popular
199€ / month
Must-have for SPECIFIC flights
- Manage Documents
- Cancel subscription anytime
- Create SORA
- Save SORA Drafts
SPECIFIC PLUS
299€ / Month
Perfect for complex operations
- Manage Documents
- Create SORA
- Save SORA Drafts
