DJI Mini 4 Pro – best memory cards
We show you which memory cards you can use for the DJI Mini 4 Pro. Image: dji.com/Montage: deindrohnenpilot.de
Which memory cards are recommended for the DJI Mini 4 Pro? We have compiled a list of suitable SD memory cards for the drone.
As with most drones from DJI, the DJI Mini 4 Pro also has an internal memory that basically allows you to take pictures without an additional memory card. However, since the memory is only 2GB small, it doesn’t have much room for many high-resolution photos or videos. Thus, anyone who seriously wants to take their Mini 4 Pro on the road will not be able to avoid buying an additional memory card.
DJI Mini 4 Pro memory cards recommendation
The following memory card is a recommendation for use with the Mini Drone. We follow DJI’s specifications and also add alternative memory cards below.
Samsung EVO Select (2021) microSD-Karte + SD-Adapter, 512 GB, Speicherkarte für Smartphone und Tablet, UHS-I U3, Full HD, 130 MB/s Lesen, MB-ME512KA/EU
  • Auf Geschwindigkeit optimierte microSD Speicherkarte perfekt für den Einsatz in Smartphones, Tablets, 360° Kameras, Full HD Action Kameras und Drohnen
  • Kompatibel mit Nintendo Switch zur einfachen Verwaltung des Speichers
  • Hohe Geschwindigkeit: geeignet für 4K UHD- und Super Slow Motion Aufnahmen mit bis zu 130 MBs Übertragungsgeschwindigkeit (UHS-I U1)
  • Viel Platz: 256 GB Speicherkapazität für bis zu 12 Stunden Aufnahmezeit von 4K UHD Videos oder 75. 200 Fotos
  • Hohe Sicherheit für Ihre Daten dank 6-fach Schutz: Wasserfest, temperaturbeständig, röntgensicher, magnetresistent, sturzsicher und verschleißfrei
Alternative microSD memory cards for DJI Mini 4 Pro
In addition to the above recommendation, the following other models are also suitable for use in the DJI Mini 4 Pro. When selecting the right size, personal usage behavior plays a role above all. The DJI Mini 4 Pro can use memory cards up to a maximum size of 512GB. We recommend at least 256GB, but ideally you should use the maximum to avoid annoying card changes.
SanDisk
Lexar
Which specifications are important for the memory card?
Important for the operation of suitable memory cards in the DJI Mini 4 Pro is the write speed of the storage medium. For 4K video recording, cards with the classification UHS-I Speed Class 3 (guaranteed minimum write speed: 30 MB/s) and the marking V30 are recommended. If you want to know more about memory cards and their standards, you can find detailed information at the following link: SD Memory Card Definitions
Do I need a memory card for the DJI Mini 4 Pro?
Since the drone has an internal memory, an external memory card is not absolutely necessary for use. However, as already mentioned, the internal memory only holds 2GB. That is enough for a few shots, but not for long photo or video sessions with 4K video material. Therefore, we recommend buying an additional memory card.
DJI Mini 4 Pro Memory Cards FAQ
Does the DJI Mini 4 Pro come with a memory card?
No, the DJI Mini 4 Pro does not come with a memory card. All info can be found in the article.
How big is the internal memory of the DJI Mini 4 Pro?
The DJI Mini 4 Pro has an internal memory of 8 GB. All info is available here.
How big can memory cards be for the DJI Mini 4 Pro?
DJI states that the DJI Mini 4 Pro supports memory cards of up to 512 GB. All info can be found here.
1 Comment
  • DJI mini pro 4. SD card speed low.(Code 1C000402) when Using SanDisk Extreme Pro 2TB SD card. UHS-1 speed class 3 rating. Speed 200MB/S read and 140BM/s write. Is it the drone a problem? SD formatted in handset
